TwinTurbo.NET: Nissan 300ZX forum - RS232 Reference Findings
Subject RS232 Reference Findings
Posted by WE350Z on August 19, 2009 at 1:05 AM
  This message has been viewed 525 times.
In Reply To 1991 OBD Pinouts / Pic posted by chromaone on August 18, 2009 at 03:00 PM
Message Well according to that pinout link you posted 156.3 KHz clock rate sounds correct based on this:
Receiver Clock Input. The frequency of this input should equal the receivers baud rate * 16
That should be 9600 bps * 16 = 156300 Hz
[ http://www.beyondlogic.org/serial/serial.htm ]
I'm wondering if there is some external controller or if some of the ECUS have differnt UART chips that perhaps run at a lower speed like some of the other ECU OBDI Ports did from other manufacturers (for instance GM ALDL OBD1 runs at 8192 bps):
[ http://www.avrfreaks.net/index.php?name=PNphpBB2&file=viewtopic&t=75516&view=next ]
[ http://www.aldlcable.com/ ]
Since the laptops serial port is configurable at multiple baud rates it can be made to work with just about any device that uses a serial cable. I just need to translate the hex datastream from my laptop's USB port out to the serial port (configured to connect to R-VIT 9600 8N1).
_____________________
2006 Scion tC (Sold)
2004 Yamaha YZF-R6 (Sold)
2003 Nissan 350Z Track (Sold)
2000 BMW X5 4.4i
1993 300ZX Twin Turbo
1985 Nissan 300ZX NA (Sold)
WE350Z at gmail dot com
http://WE350Z.com
